I have a little problem with a particular kind of scene I tried to do.
My idea is to have a dolly movement of camera syncronized to a change of FOV.
In pratical i tried to have a zoom out while I go ahead. In my mind I tried to fix a point of an object while all around change prospective.
This is start frame
This is end frame
Unfortunately the result is not was as good as I imagined.
I think because I can’t control the curve of FOV interpolation.
While I can flag “Easy in/out” in camera movement, I cannot set the same thing in FOV interpolation.
This produce an unaesthetic elestic effect that dirties the result.
Can you add more controls to better set this type of conditions?
Hey @happymilk_2 !
I think I get what you want to achieve exactly, but correct me if I miss anything - you basically want the FoV adjustment to be most noticeable in about the middle of the camerapath, but the beginning and end should be similar to what you get with the “easing in/out” function, just for FoV (making it slower/smoother too), correct? Let me know and I’ll gladly discuss this internally.
Hi Demian,
first, sorry for my english. I know that is a big problem in most cases.
What i try to achieve is a linear transition from two keyframes.
I can obtain it in the camera movement (with easy in/out set to off) but not in FOV aperture that seems always smooth.
I try to show you what i would.
(this is lightwave 3D preview)
And this is a graph timeline from the 2 keyframe
I hope it’s more clear now.
Mirko
