Control of Grass Overgrowth at Edges
We do a lot of planters and the 3D grass always produces an issue at the edge of the planter wall. I know I could pull the surface back but then it looks bad in architectural documentation. Its important that we have the control that the grass be able to stop at a hard edge, and not overflow. In some cases the overflow is fine but we need the choice
@mattendler The topic is already on our agenda but has a quite high complexity.
Is it a possible workaround for you to
  • Draw a transition zone between the grass material and the planter wall?
  • Increase the thickness of the planter wall?
