Control Vantage externally
Dear Chaos,
Is it possible to control vantage from command line (CMD) if a scene in vantage is open?
The controls i would like to have externally are:
- Cam position or camera name in vantage
- Group / Objects on or off
- Load vantage config file
- Render screenshot to path
The reason we are asking this is because we would like tot render the images bij command prompt.
yes, I care too.
when I need to take a series of screenshot, command line to control position of camera will be very very usefull. come on Vantage
We’ve added command line rendering in 1.5.0 - see “vantage_console.exe --help”.
This we already tried but we miss the possibility to render from an scene which is already open.
If a scene is not autoclosed, the command line isn’t accesible after rendering and if we set up the scene before starting the command line render, it starts a new instance.
So it doesn’t detect if there is already a scene open.
