as per this thread: vrayhairnext material, colour from texture, best practice. - V-Ray for 3ds Max :: General - Chaos Forum
there seems no simple “correct” way to use fur colour map in the vrayhairnext material. or at least, nobody from Chaos has chipped in to explain a correct workflow.
I was speaking to another Cgi artist who, in the past, remebers using a Mari node which converted an RGB hair color texture into seperate greyscale maps to control melanin and pheomelanin, and produce a correct result. obviously this will only work with physically plausible hair/fur colours, but it would be very helpful if anyone can suggest a way to do this, assuming there is not a way to simply use the rgb directly without having to use silly gamma settings and color correction tweaks to get a plausible result.
