Have my scene with all Max cams, and want to try the vraycam, ive aligned the camera and camera target to match the old max cam.
But it doesnt seem to render the same, It has the correct lens settings.
Have also put in the camera section under the vray render settings to overide the fov to the same as the max cam.
Is there a full proof method to get the same result?
Look into Lele’s anything to vraycam script
can you post a link to that script please? I searched the forum and could not find it.
Thanks!
sticky in the OT section, it’s inside the pack. Has issues with animation, so make sure you save your scene if it has animated cameras in. In general, i suggest you to convert the camera first, whenever possible, and animate later.
Lele
Thanks! Thanks for writing such an awesome script!
