Convert proxy back to editable poly ?
I had a question. Goes some way to convert proxy model back to editable poly?
I have formed the roof and I need her re-edit and re-converted to the proxy.
Duplicate to mesh in the proxy settings? or if you display it as full mesh you might be able to just convert to edit poly
When you set up a full mesh so I do not have the option to convert to editable poly or copied :frowning:
You can convert it to editable mesh and then convert it to editable poly.
Problem solved. 3ds Max 2012 does not convert to editable mesh. 3ds Max 2015 works as you write. thanks :smiley:
