there is any way to covert value from v-ray cam to max standard (max min value +500 -500) modifier?
i’m making a AO pass with mental ray and the good pass with v-ray, but the two images doesn’t match
thank you
thank you
Why are you using MR for an AO pass and not Vray?
I mean, if you would ask for this because you’re rendering volumetrics with MR I would understand your need, but why are you struggling with camera matching when you can do AO passes in VRay just fine?
A.
And u can use material override with vray dirt, and tweak the radius. At least i do that. And it works.
i remember that there is a free script which transfers a vray cam to a standard cam…
probably you can find it at script spot
ok i was able to resolve my problem easily, rebooting my pc.
The vray cam can work correctly whit mental ray.
thank you to all.
