Converter and Lightconverter doesn't work with Alpha6
Hi
I’ve just began to work with the Alpha6 today and tried to import a VRay scene to Corona.
But when I want to convert my shaders there is a crash of the converter; here is the highlighted line in the script (when I click on “Start Converting”)
r.emissionOn = (if (origMtl.useSelfIllumColor AND origMtl.selfIllumColor != (color 0 0 0)) OR origMtl.selfIllumAmount != 0 then true else false)
And then I wanted to try the LightConverter V0.06 but it bugs too (directly when I run the script)
CorLight.sphereRadius = orignLight.size0
Hope it will help, but I can’t work with Corona for this project…
Are you using the latest converter version? (0.15)
AFAIK, the new material converter works, but the light changer doesn’t yet work with A6.
… of the converter ? I don’t know I’m shaking that
yea the new material converter def. works ,but not the light converter with A6. :frowning:
Yes converter does not work in a6 sadness
