I’m trying to convert a corona material to vray.
It has a Translucency Fraction map that makes a huge difference in the rendering and I can’t find the equivalence in vray.
If I apply the corona material to the objects and render them in vray, vray converts them on the fly and render them fine.
This makes me think that Vray does understand what that setting/map is, so I’m trying to find how I can set that up correctly in a vray material to avoid having the on the fly conversion.
You should have a reply on your ticket about this request. but will post a copy here just in case.
Here are 2 options that you can use to get the same effect in V-Ray as using translucency fraction in Corona:
VRayMtl
Enable “Thin-walled” option under refraction
Set translucency to “SSS”
Control translucency fraction with the “SSS amount” value
Note: when using this method, the translucency fraction cannot be mapped. This is solved in the below solution:
VRay2SidedMtl
Plug your “main” material into the “Front material” slot (it should not have the SSS enabled, it does not need any special settings, it can be just a VRayMtl with a diffuse texture, for example)
Plug the texture which you wish to use to control the translucency fraction into the “Translucency” slot (“translucencyTex” in the shader network)
