Copy all Material Attributes to an existing Sketchup Material - how to
I have a scene with existing materials.
Example: GlasWindow
These material-names shall be not replaced!
But I whant to improve the Scene with materials from Chaos Cosmos.
I tried arround a lot with “Use as a replacement”
But this is not what i want to achive!
I whant to:
1. Download a material
2. Coppy all settings to an existing (selekted) material
3. Or better: Download a material and replace alle settings to the selected material.
Is there any way to do this?
Regards Ronald
If keeping the original material name is important, why not “use as replacement” and then rename the material you have replaced with, now that the original is not being used?
In the VRay Asset Editor -
1. Import “Cosmos Material”
2. Select “Cosmos Material” - “Use as Replacement”
3. Select “Sketchup Material” - “Replace in Scene”
4. Delete “Sketchup Material”
5. Rename “Cosmos Material” to “Sketchup Material”
Hello @Kissling ​.
In addition to @AKlypin 's​ proposal, in step 3 you can also use the option “Replace All References” to easily replace all references of the old material, used as part of Multi Material or Two Sided material or as a material in a Proxy Mesh.
Regards,
Ivelina
