Full-speed non-debug version
Build timestamp: Feb 5 2018 10:05:29
Version: B1 (core 1.7)
Cinema version: CINEMA 4D Studio R19.053 S
Plugin status: initialized successfully
Mac OS Sierra 12.12.4
If you have a Layered material in a scene and want to copy and paste it, or the objects and materials, only the Layered material itself is copied, but not the supporting materials that comprise the layers. This happens every time. Not a major bug, but very annoying if you have many materials. Right now, I have to go back and copy the missing materials and paste again into the new scene, then re-stack the layers.
I think that’s the concept that Cinema4D simply doesn’t acknowledge. There’s no C4D layered material in AR or PR, so there’s no need to support such action with the code (no referencing a material within a material) - observed same in Indigo.
bypass Copy/Paste them all in one go/single action (this way connections stay; also watch out for naming conventions - no duplicates)
disclaimer
Based on experience so, let developers chime in, explain, confirm…
In any case, yes it’s up to us to try to find a workaroud (i.e. an ugly hack) that will allow to copy such materials. Maybe it won’t be reasonably possible at all, so we’ll have to make a compromise (as happens very often). And yes, C4D doesn’t allow for materials within materials.
