Copy paste texture missing
I want to copy some objects with V-ray textures to an other sketchup file, the problem is sometimes textures maps are missing, for exemple on diffuse it is written “texture.jpg” like my picture.
Notice that my previous files is saved, and all textures are saved also and the directory hasn’t been moved.
Hello, mrmaxime_gilbert,
Thank you for your report. I am not able to reproduce the issue so far. Could you please send us a packed project of a scene with the problematic object (Extensions > V-Ray Menu > Pack Project)? You can send the archive here or via a support request.
Kind regards,
Iva
Hello @mrmaxime_gilbert !
There is one known issue related to materials with Layered textures. They sometimes are not copy - pasted correctly between projects if their Viewport Display Texture option is set to “Auto” (logged in our system as SK-5484). If that is the case, can you try to set this option to “Custom” and tell us if that helps?
Thank you in advanced.
Regards,
Ivelina
