I am adding a texture on a surface and it automatically becames diffuse, that is fine.. But when i want to add a color correction to the diffuse, i copy the texture, click on the diffuse map, select the color correction and paste the old diffuse texture into it, it goes, paste option is empty.. It was working with vray 3. or lower..
Hi kenancakir,
The described workflow was an option in V3 but was causing some hidden issues.
Removing it was necessary to resolve those and was done as a fix.
In V-Ray Next you should use a slightly different approach:
1. Add the texture to the Diffuse slot
2. Select the material (you can use Ctrl + Up as a shortcut to do so)
3. Right-Click on the Diffuse texture slot
4. Expand the Wrap In menu and select Color Correction from there
This will create a new CC map and place it in-between the material and the texture.
Hope that helps,
Konstantin
Thank you, today i watched your webinar and learned it..
