Copying Cosmos trees from project to project
When I copy a cosmos tree into another c4d project not all materials are transferred.
The leaves of the cosmos trees use doublesided materials that reference two distinct front and back materials. While the doublelsided material is applied correctly the materials it references are left behind. Naturally the leaves don’t render anymore.
How can I ensure that all materials are copied with the Proxy?
ave I missed something or is this a bug?
Thanks in advance
CLH
P.S.: I did see the topic with a very similar title but the problem is not quite the same.
This is the way it works an it is annoying for sure, here is a quick fix:
Thank you. Works like a charm.
