I have a problem with corona AO map in bump map slot. it doest work either as bump map and masking for bump.
Please note that it happens ONLY in bump map slot
Any solution?
Any solution?
this is a limitation of the texture. Bump mapping requires filtering in texture space, but since AO is procedural map dependent on scene, there is no texture space. It is the same reason why for example fresnel won’t work. But I guess I could fake it so it blends results of 2 bump maps… not 100% correct, but probably close enough
Any update on this you kind Corona people ![]()
Not sure what is needed exactly, but here is an example I made recently for someone with similar question:
Ah, I remember now. I stumbled across this fix before but I forgot.
It does seem as if this could be fixed though without the need for this.
Thanks for the help Maru.
