I am having a similar issue. My workstation can handle the file and render locally just fine, and it works on the render slave when DR’d, but if I open the file on any other workstation in the office this happens when I try to render, and Max is incredibly sluggish.
Not running DR server on anything else. I haven’t tried 1.2, I’m still on the 1.1 trial. I’m just seeing if max 2015/2016 has the same problem. I’ll try 1.2 next.
edit: Just wanted to add that it doesn’t happen with corona scenes built from scratch it’s only happening with a fairly dense scene that i converted from vray 2.5…
Is there displacement on any material in that scene? (if you are not sure, you can untick displacement in F10 > common > options and then see if there is any difference in rendering )
there’s no displacement and its un-ticked in common.
2015/2016 had the same problem. I just installed the 1.2 trial and it is doing the same thing. Is there a corona log somewhere I can look at? It would be really great to find a solution as we are seriously looking into deploying corona here
One thing we noticed after coming back from lunch and some more testing is that it appears to be a couple of the xref model files that are quite large. The only types of geometry that they have in common are proxies converted from vray… But there are other less large files with proxies that are ok.
We’ll try and narrow the problem down a bit more and try to strip the file down and send to you guys.
Also if we leave it “transforming vertices” it will eventually move on to parsing the scene, and correct saying its rendering frame 0. However it seems stuck there now.
Xref models might be the cause. Can you try removing them just for test, or merging into scene? We’ve already had some reports where xrefs would do ugly things.
Well, it does work without 2 of the xrefs model files, but those files don’t render when merged in/opened on their own.
I think we’ve narrowed it down to a material that corrupts when converted to corona because the original vray scene renders with a simple corona material set to override.
Hopefully we can find the material that is the cause and i’ll post here and corona material converter thread.
We weren’t able to narrow it down to a specific material. But any of the objects using an xref material were fine.
We’ve also discovered that the broken file render eventually and can get “stuck” at different points, on some computers it is at transforming vertices, at others it is building acc., etc.
I’m uploading the scene to the helpdesk now. It is able to render, but it takes an age to get to the pass stage. And maneuvering in the view port is nearly impossible because it is so laggy. Also compared to vray the file takes noticeably longer to open.
I found a bunch of instances of WSCommCntr4.exe in the fault tolerant log. I renamed the exe so it won’t run anymore, the problem seems to have gone on at least 2 machines in the office. Will test on a 3rd later today. Still trying to find time to test the latest Daily as recommended by Maru.
