I have some issue with the corona 1.5 installer.
The installer stop when microsoft dependencies are checked, then he stop with KB 2999226 x64 is needed.
I just formated my slave and same issue. I’m on windows seven, i checked all the update and it’s ok.
Very usefull thank a lot !
Actually i updated windows manualy with wsuoffline, after that i will check if is ok or not.
I didn’t test with unpack files method.
Ok just after unpacked on a files and start the windows installers manualy, i got the message “don’t work on your computer”
Windows Seven, sp1 installed, got 2 other hp z620 with the same config and the installer work fine.
Any idea ?
thx.
I had a similar machine (Win7 with SP) that refused to install Corona, I had to install the ms redist files several times, at some point it went through.
