Corona 1.7 Hair n Fur not support texture mapping and..
I start to use 1.7 and Hair and Fur not support mapping..
this is a big problem if you want to create a carpet or fur like jaguar (what I have to do :((((((
also in Dr, slaves not read cache fur file simulation.
Will these problems be solved?
It works. You have to use the parameter of Hair and Fur Material Parameters rollout. (Tip Color and Root Color)
But you loose all CoronaHair parameters that way, so from my point of view it doesn’t work. Well, at least not how it should. But as Ondra said, it’s autodesk to blame for that :[
Okay thanks, I had tried to use a map in Mutant Color using a material in Mr Shader. It was an alternative solution, though not perfect.
And for Dr problem?
Is the fur cache file picked up by asset tracking? (Shift+T)
If so, there should be no reason why it wouldn’t work in DR.
As a temporary workaround you can try placing the cache file on a network drive where it can be reached by all PCs.
Yes Romullus. But, for carpet, we don’t need so “realistic hairs” shader. =)
what is used without coronahairmtl plugged in is actually also hair mtl, just with its properties mapped into the native controls
Ondra, could you tell us what exactly properties are mapped? Is it just diffuse colour, or something more?
It find “Fur.stat” file (I’don’t know if read this as sequence) BUT the result is this..
(file attached)
WHY???
Is a Bug in DR…
Problem solved…I’don’t know why…but Asset Tracking was disabled…
Link for who have same problem:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Cannot-login-into-Vault-from-3ds-Max.html
SORRY…wrong IS STILL NOT WORKING…aaaaaahhhhhh :(((((
Confirmed. It’s a bug. .stat file isn’t recognized in DR.
The Slave isn’t able to read the .stat file from H&F simulation.
with BB everything is ok.
Okay. A day lost trying to make it work.
I would like to know from administrators if the bug will be fixed.
:confused:
Of course =) It will be fixed.
I know, but now I’m in the middle of a work project, so I want to know if I have to wait to render the animation.
:smiley:
You have discovered this bug today. Give time to the team :wink:
Also, the H&F material is still not technically released in a stable build yet. There is always the warning of using daily builds at your own risk. As always, if you have a mission critical delivery, you should not use the daily builds.
yes guys, as Njen said, daily build in every software is for testing and playing purpose only. unless you know exactly which feature is production ready and which feature is still in development.
also the glosiness and opacity (if it is present)
