Corona 10.2 CoronaMultiTexture/CoronaColorCorrect crash
Hey guys,
I’ve had a scene regularly crashing on me - I initially thought it might be due to a bad downloaded asset but since dropping in another one the issue persists.
The object renders fine using the material the object came with but crashes after around 20 passes or so if I insert a CoronaColorCorrect or a CoronaMultiMap into the material tree.
Minidump attached.
3dsmax_minidump.7z (1.44 MB)
Hey Sam,
Is there a chance you could share the scene with me?
Thanks,
Rowan
Hey Rowan,
I’ve managed to work around the issue but I’ll get that over to you ASAP.
I just need to make sure it’s still crashing without the stuff that I can’t include so may take a couple of extra days.
Will reply here when sent.
Cheers
Hi Sam,
Do you still need help with this or is this solved?
Hi Avi,
Apologies for not sending the scene over.
We’ve since updated to Corona 11.1 and so far haven’t run into the crash.
Cheers
Thanks for the prompt reply.
In that case, feel free to get in touch if you need any further help.
