Chaos Corona 10 for 3ds Max and Cinema 4D released!
Let yourself be driven by creativity, thanks to Corona 10’s focus on giving you a smoother workflow and more artistic options so that you can achieve the results you want!
Full details and download: https://blog.corona-renderer.com/chaos-corona-10-released/
- Easily add cracks, dirt, stickers, etching, embossing, and more thanks to individual control over the material channels (Diffuse, Displacement, Metalness, etc.) affected by a Corona Decal.
- Fly cameras through smoke and clouds, or have them half-submerged in water with accurate rendering from Cameras inside volumetric materials such as those from Phoenix simulations.
- Brighter, more accurate Caustics when rendering to large resolutions.
- Greatly improved highlight blurring when using Depth of Field.
- Easily find and adjust scatters, lights, proxies, displacement, and cameras using the new Listers.
- Apply the same Triplanar, Color Correction, or Mapping Randomizer settings to multiple maps at once with new multi input and output options. No longer will you have to edit multiple nodes or spend time setting up control nodes to keep different maps in sync.
For this release, everyone gets a full 30-day trial period, even if you have used a trial before, to give you time to try out all the new features.
Remember, you can read about this release in detail over at https://blog.corona-renderer.com/chaos-corona-10-released/
