Been struggling to try and figure out why this keeps happening. Trying to create an animation underwater only using PhoenixFDOceantex and Coronavolumetric parameter. I’ve tried many different settings and still the same. NOW when I turn off the Oceantex it renders fine with no crashing so I’m going to assume that it is the Ocean tex that isn’t working properly. It also happens only in the underwater shot. Rendering the animation above the water it seems ok. Anyone else having issues with the Oceantex and Corona Renderer 10? Thanks!
This is the sample frame
Can you send over the scene so that we can check it out?
You can send it via https://support.chaos.com/hc/en-us (there is a submit a request button at the top right)
Thanks!
