Corona 11 bug ?
Hi all
I recently installed corona 11 ( with c4d R20 and also with C4d 2024 ).
I have a pb with the override fonction of the cam. It doesn t seem to work anymore.
In th e VFB i have this message : “camera was removed, controls… wont be synchronized” even if the camera is active and selected.
Am I the only one to have this pb ?
Fab
And another point :
It s seems that the decals are rendered far slowlier compared to corona 10 hotfix2
Hi there, I’m not sure I really understand your first post. Can you share an image or test scene? As for the second post, can you also share a comparison between the two?
yes sure . Sorry if it s not very understandable .
Here s a print screen ( i have the pb in any scene in fact ) .
If i change the “simple exposure” for example in the VFB it doesn t change in the properties of the cam despite the tone mapping is “override”
It s the same problem with other parameters ( blomm and glare, sharpening , … )
PS : the materials you can see are all made with new tile shader ( + multi shader and mapping randomizer ) , it s very cool :laughing:
Hello Beanzvision,
it’s the same problem like in this thread: https://forum.corona-renderer.com/ Incorrect colors on VFB x Pic Viewer RC3
or in this one: https://forum.corona-renderer.com/ Corona 11 for Cinema 4D (Release Candidate 1 and 2) - VFB and Corona camera tag
Greeting
Thanks! We do have this logged and it will be addressed. :smiley:
thanks
