installed corona12, some vray basic materials are not supported as for corona 11.
Corona converter not solve so I can not upgrade.
Any Advise?
Thank you
Any Advise?
Thank you
Can you please send over a scene which has these materials/objects, which, as you say, converted fine with Corona Converter in Corona 11 but not in Corona 12?
This way we will be able to have a better look at the possible issue.
Hi, thank you for answer.
Using corona 11:
no need to convert any materials, i can render without problem.
Using corona 12:
when i try to render the same scene i receive maeesages of materials that are not supported, when i try to convert it are not converted.
This is more clear now.
A scene with these materials will be definitely necessary to investigate the issue.
Can you send it over?
Not at ance, but I will send the scene.
There is a link for upload?
The best way will be to submit a ticket and attach to it at:
https://support.chaos.com/hc/en-us/requests/new
Please add this forum thread link in the ticket too to better track everything.
Thanks.
usung corona 12, I notice that all vray materials are not recognized, maybe i had to reinstall vray (demo)?
Solved installing the last Vray release.
Happy to hear that!
Solved also after the trial period of vray, right?
Yes, V-Ray license validity should not be a problem here. As Aram asked, please submit a support ticket with the problematic scene archived with all assets: https://support.chaos.com/hc/en-us/requests/new
Thank you in advance!
Hi maru,
the problem was not the scene but something like version of vray.
All scenes with vray materials did nor worked before the new installation of vray.
