Corona 12, update 1 (Hotfix 1) released for 3ds Max & Cinema 4D
This hotfix addresses specific issues, and all Corona 12, update 1 users, for both 3ds Max and Cinema 4D, are recommended to download it. Find more details below.
Download now: chaos.com/corona/download
Chaos Corona 12, update 1 for 3ds Max (Hotfix 1)
This release brings the following improvements and bug fixes:
Changes:
  • Chaos installer advanced install - “continue” button is now disabled when no component is selected.
  • 3ds Max shortcuts are now disabled for Cosmos sign-in dialog.
  • Fixed issue where ForestPack IVY was not animated in production rendering.
  • Fixed issue where ForestPack was no longer scattering Corona light sources.
  • Fixed issue where light sources scattered with ForestPack were all in the same light mix selection.
  • Improved overall responsiveness of UI when rendering with Corona.
Scanned Material:
  • Fixed “Advanced” dialog not being hidden when license is not available.
  • Fixed loading of material when relative paths are stored (Preference Settings > Files > Convert local file paths to Relative).
  • License is not obtained immediately after creating the scanned material anymore. It is obtained only when UI is displayed or when writing new parameter values.
Chaos Corona 12, update 1 for Cinema 4D (Hotfix 1)
This release brings the following bug fixes and improvements:
Changes:
  • Fixed VFB2 not showing the rendered image with correct color transformation when “Use Cinema 4D color space” is enabled.
  • Fixed issue with some keys not working in Cloud Collaboration tab (e.g. home/end keys when editing project name).
  • Fixed issue with Escape key in Cloud Collaboration (and some specific other widgets in VFB2) causing VFB2 to stop updating.
  • Fixed incorrectly loaded UV pattern mode in Chaos Scatter for scenes saved in previous Scatter versions.
  • Fixed UV pattern mode not showing correct default value when new Chaos Scatter is created.
  • Added randomization compatibility option and fixed randomization compatibility for scenes saved in Scatter 5.
  • Fixed issues with mouse freezing while terminating C4D after cloud collaboration was opened.
  • Fixed some possible performance issues for mouse inputs.
  • Updated Cosmos to version 2025.1.8.
