Hi all,
Is there a way to compress or downsize texture at rendering. I have a bunch of 8k texture and don’t to modify them in photoshop.
Thank you
Hi all,
Thank you
If out of core is enabled in your render setup performance tab (should be on by default, unless you turned it off) and you’re using Corona bitmaps for your textures, then Corona automatically resizes and loads optimal resolution textures during rendering.
Yup, you can learn more about it here: https://support.chaos.com/hc/en-us/articles/9477508142993-Out-of-core-Rendering-for-textures-3ds-Max
Perfect, thank you very much for your replies!
