Corona 4 Hotfix 1 needed
i asked rebusfarm which version they are using.
They say „We are working with Corona 4 Hotfix 1“
I use Hotfix 2. Now i want render with rebus (just stils).
What do i have to do now. Downgrade? Where can i get Hotfix 1?
What happens with my scenes (i build with hotfix 2) when i open them with Hotfix 1?
Which Renderfarm works with Hotfix 2?
Wolfgang
You are probably on a Mac, since I can’t remember having seen a hotfix 2 for windows.
The only difference the changelog has between hf 1 and 2 is “Fixed nonworking Corona Licensing Server on macOS”, so there should not be any functional difference to hf1 when it comes to Corona features themselves.
You should find a dropbox link to hf1 somewhere in this thread
https://forum.corona-renderer.com/ Corona Renderer 4 for Cinema 4D daily build
but I was to lazy to find it myself :wink:
My assumption would be: your scene will be working fine with the farm, but I can’t say for sure.
Hello Cinemike, thanks! I‘ll try it with my Hotfix 2.
Good luck!
If it works - a accept donations.
If it fails - I never said a word!
Hi Cinemike,
it works! And the Rebus-Supprt is very good.
But another question:
When i want to render in distributed mode, there are many limitations like
no caustics, no LightMix, no Multilayer, no Takes (Take-System)
That means much work to prepare the scenes for Rebus.
Is this a problem of Rebus?
When yes, is there another Renderfarm that works without these limitations?
Sys-Konfig: MacPro, OS 10.13.6, Cinema 4D R19/R20, Corona 4
