Corona 4 - Interactive Blurred
Since I started using Corona 4 I feel the interactive mode blurred as if I was using DOF mode on. I’ve tried using it in 3dsMax 2018, 2019 and 2020. Is someone experiencing the issue?
It might be upscaling factor. Go to render setup>system>system settings and see what’s the image upscale factor value - should be 1.0
Yeah this sounds like the image upscaling factor, currently it takes it’s default setting from the windows scaling settings.
I guess this is casuing some confusion. We will look into it.
Thanks,
Rowan
(Internal ID = 363672894)
Perfect. Problem solved. Thanks guys!
Aye this definitely needs to be fixed please :smiley:
