i have problem with corona 4 (15.05 build) and hdri map. I’m using IR, changing HDRI rotation (loaded as corona bitmap), and nothing refreshes in IR window. In corona 3 everything worked good. Is this bug ?
Edit: HDRI loaded as vrayhdri map work good.
Hi, I just tried this with V4 RC1 and everything seems to be working as expected. Can you also try RC1 and let us know if there is still some problem? In such case we will need either precise repro steps (what exactly you are loading, where, how), or a video recording showing how to reproduce the issue.
