Hi Guys,
I just tested the new 2.5 displacement feature (which is awesome) and realized that something isn’t right when I put the displacement map into a corona triplanar.
I don’t know if that is already supposed to work but maybe you would like to take a look on that.
I attached a test result:
I am unable to reproduce this behaviour. Are you using the latest version of Corona?
If so, would you be able to send over your scene?
Thanks,
Rowan
Hi!
I used the last Daily before the RC 1 for this test but now I updated and tested again. I’ve got the some results.
I can send over the scene. Is there a specific email address for that?
Cheers,
Manó
If the scene is confidential, then use this private uploader: Chaos
If it can be shared publicly and the size is not very big, then you can simply attach it to the forum message.
