Corona 7 not showing in Team Render clients
The latest daily build doesn’t load when I start a Team Render client (R23). There’s no log in the console as if it weren’t installed, but it loads ok in the Cinema 4D editor. It’s the same across several machines.
All machines are running OSX (Mojave or Catalina).
I can confirm the same thing happens for Windows. We’ll look into it.
Thank you for reporting,
Jan
Hello again,
the issue is actually on the C4D side (Their Client has issues recognizing plugins). You can manually add the plugins by:
  1. Open C4d Team Render Client
  2. File>Preferences
  3. Plugins
  4. Add Folder
  5. Locate corona folder inside your R23 folder>plugins
Next time you start Client, corona will be working!
Thanks,
Jan
It works! Woohoo!
Thanks very much,
Rob
