Corona 7 scene converter problem
hi guys i am having some problems with the new converter and the physical materials:
1- it converts some random materials in the scene to physical metallic material which was already corona material [ bed sheets for example]
2- i cant convert this physical material to any other engine material vray, fstorm etc.. it just becomes black
did anyone experience the same and have you found a solution ?
You can find reports and discussion of point 1 in https://forum.corona-renderer.com/ The new Corona Converter feedback thread
As for the second, until someone from the other render engine writes a converter to work with the Physical Material, it will not be possible to convert it to that engine. Any existing converter will only convert Legacy Material since that was all that was around at the time, and they would need new code to convert the new Physical Material. Hope this helps!
