Corona 8 Node Render License
Unfortunately the support doesn’t answer. So I ask here: After we installed Corona 8 on the farm machines they don’t render anymore. How can I tell the nodes where the license server is located?
Hi, I can see your support ticket. I will reply in there and then save the information here so that others can find it if needed.
Sorry for the delay. We generally do our best to respond within 24 hours, but this isn’t always possible.
Thanks! Fine!. Maybe it is not only a licensing problem. Please see attached screeshot. Corona 8 is complete installed.
Hi is there any answer to this?
I haven’t changed anything since v7 which worked fine, but after installing v8 the rendernode no longer starts.
On the render node please make sure that you are signed into the Chaos licensing server (http://127.0.0.1:30304).
If you continue to have problems after ensuring that you are signed in, please let me know and I’ll be able to provide some more steps.
Rowan
In case of the original report, the user was using Windows 7, which is not supported by Corona 8.
Corona 8 won’t work on Windows 7 regardless if it’s used on a workstation or render node.
Hi there,
Having a similar issue to the previous user. Corona 7.1 was working fine on the rendernodes but now that i’ve installed Corona 8 they are not working.
Have signed into the license server on all the nodes but when they start in 3ds max they are saying, Corona license not found!
Any ideas?
Could you please contact us here and include the information if you are using Corona 8 or Corona 8 Hotfix 1?
https://support.chaos.com/hc/en-us/requests/new
HI There,
I already have. My ticket number is 44759.
We installed the latest software. So Corona 8 HOTFIX 1
Do i need to do it again?
