Corona 9 scatter edge trimming
hi !
I’m using corona 9 with map edge trimming but it doesn’t work… any ideas? I read the solutions provided before but it doesn’t work.
Thank you for your help i can’t the solution
DG
I guess you’re using proxies to scatter with?
You have to set the display mode (of the original proxy object) to ‘full mesh’ for it to work as expected.
Thank you for your reply
But no, I’ve import in the scene a file maxtree with different grass . I’ve 6 different grass, Isn’t a proxy
Did you try to reset x-form of scattered objects?
no I don’t know how to do it
Here’s official guide from Autodesk: Help
we also mention resetting Xform as a solution to some Scatter issues in our help center articles: https://support.chaos.com/hc/en-us/articles/4953457092625-How-to-use-Chaos-Scatter-with-Corona-for-3ds-Max-Performance-and-Troubleshooting
