Corona 9 Sky Texmap Volume Effect with Clouds?
I’m trying to use the new clouds with corona in the sky texmap but when I enable the volume effect it cuts off the clouds of in the horizon line, is there any way to fix or blend this? If I turn of volume effect it looks fine but I like the effect on. Thanks!
This is known issue. Currently aerial volume and clouds cannot be used together, you can have either one, or another. This might, or might not be solved in the future.
Ah okay noted, thanks for the reply :smiley:
