Corona Alpha4 Benchmark scene
This is archived thread, we have released an improved benchmark based on newer Corona version: Corona 1.3 Benchmark - Corona for 3ds Max :: General - Chaos Forum - you should use only this one.
I’ve prepared a standalone version of Corona to run a prepared scene with a reference configuration, and report the rendering time. It is a nice demo of Corona capabilities, and you can use it to judge how fast can your computer run Corona, and what would you gain by upgrading it
You can download it here, to run it, simply download, unpack, run the .bat file:
http://corona-renderer.com/stuff/a4-benchmark
It requires x64 Windows Vista or newer, and Intel Core 2 9xxx or newer, or AMD equivalent. It does not require 3ds max to run. You have to have MSVC redistributable installed to run the application: http://www.microsoft.com/en-us/download/details.aspx?id=13523
It runs for about 5-15 minutes on most computers, then it will pop up windows with copypastable info (and save image to its folder). To get best results, you should not perform any CPU-heavy operations while it is running
Feel free to post your test results
Copyright notice: The model and textures are property of its authors, and it is forbidden to use them outside of this application.
Disclaimer about the speed of the rendering, since many people discuss if the scene is somehow “cheated”: The rendering runs in a partially biased mode with partial lighting interpolation (irradiance caching/light caching-style) enabled, it is not pure path tracing nor unbiased. The settings are slightly tweaked to achieve best performance (about 3 parameters are changed, because by default they are set defensively to allow reasonable rendering of much more complex scenes), and the scene uses portal lighting. Any professional Corona user would be able to tweak the scene the same way. The scene is a real scene created by an artist, with not subsequent tweaking such as removal of geometry. Effect of turning portals on/off is shown here
PS: Here is the original .max scene: Sample interior scene - Corona Common :: Announcements - Chaos Forum
I’ll start
Corona Renderer Alpha 4 benchmark scene
Living room 100 passes
Intel(R) Core™ i7-2600 CPU @ 3.40GHz
Time: 0:5:59, Rays/s: 3,541,597
Wonderfull!!!
When I run the batch file generates an error file not found “wxmsw294u_core_vc_custom.dll” (((
Intel(R) Xeon(R) CPU E5520 @ 2.27GHz
Time: 0:4:56, Rays/s: 4,291,727
btw, 2x xeon cpus
and i got a crash on the first try to open it but it worked on the second try
Ok downloading..
It will be great to ctreate table with pc specs and speed results for comparison..
Intel(R) Core™ i7-2600K CPU @ 4.30GHz
Time: 0:4:48, Rays/s: 4,414,286
](http://www22.zippyshare.com/v/40325708/file.html)
Did the entire archive unpack OK?
Passes: 100
CPU: Intel(R) Core™ i7-3930K CPU @ 4.50GHz
Rays/s: 5,924,060
Time: 0:3:34
add with post :smiley:
Dooooooo want. At least a Standaloneversion, that would be greate.
Intel(R) Core™ i7 CPU 920 @ 2.67GHz
Time: 0:8:16, Rays/s: 2,567,451
Edit: One strange behaviour is that on some CPUs or Systeme Corona shoots al lot more rays than on other, on 100 Passes. (Compare my 2.5Mio vs nearly 6Mio on the Guy above this Post)
Sorry, I unpack archive before it completely downloaded :). Now is all ok!
Intel(R) Core™ i7 CPU 870 @ 2.93GHz
Time: 0:8:2, Rays/s: 2,640,659
Yes, the save button does not work, but it saves automatically into the folder with bat file.
Same here.
Intel(R) Core™ i7-2600K CPU @ 3.40GHz
Time: 0:12:47, Rays/s: 1,656,537
Intel(R) Core™ i7-3930K CPU @ 3.20GHz
Time: 0:4:4, Rays/s: 5,204,257
Intel(R) Core™ i7-3820 CPU @ 3.60GHz
Time: 0:5:49, Rays/s: 3,634,792
Intel(R) Core™ i7 CPU 980 @ 3.60GHz
Time: 0:4:28, Rays/s: 4,736,817
I’m speed up my computer to 4 GHZ and got a new result:
Intel(R) Core™ i7 CPU 980 @ 4.04GHz
Time: 0:3:43, Rays/s: 5,703,057
Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
Time: 0:2:56, Rays/s: 7,210,707
its actually 2x CPU and they both run at OC 3.6ghz :smiley:
Low end representation here! But it’s also informative, right?
Intel(R) Core™ i3 CPU M 370 @ 2.40GHz
Time: 0:19:42, Rays/s: 1,076,912
Isn’t posting the images here pointless, as they all will look exactly the same?
