So, something weird has happened and I don’t have any clue what is causing it. I have R23 110. And I was using V6 hotfix 1 of Corona Renderer. At first, When I tried to render a scene, it crashes C4D completely. Then it got to the point of even if I load a corona texture, it crashes C4D completely. Doesn’t matter what project I’m in. Can be a brand new project. I uninstalled corona and tried a reinstall. Then I upgraded to Corona 6 hotfix 2. Than I upgraded to Corona 7. Same thing still. Then I unstalled all versions of C4D and reinstalled R23. Same problem still. Then I installed R25 and reinstalled Corona 7. Same thing still. It can be a scene with nothing in it. When I try to creat a new corona material, it crashes C4D. I’m on windows 10 21H2, running an AMD Threadripper 3960X 24c. 128Gb of ram with a RTX2080ti card. The only thing I haven’t tried is doing a full reset of Windows. I can’t revert back a few days, because I don’t have that option available. Is it anything to do with runtime or a framework? Any help would be appreciated. Attached is the bug report. Maybe one of you fine people may be able to tell me what’s happening. Thanks!
_BugReport.txt (1.01 MB)
Hi there, sounds like it might be something else other than Corona. Does it happen if you switch to the standard renderer or another? Can you also send us the .dmp minidump file also located where the bug reports are?
(Internal ID=860971811)
Can we assume if you uninstall Corona, C4D works as expected?
