I am using Deadline to submit jobs to Network Rendering and everytime i try to render something on corona, using render elements, the Deadline Submition script crashes. So i have to render the elements on my local machine and only the Beauty using corona on network…
It looks like that's a problem with Deadline right ? Not on Corona...Or maybe it's a kind of bug ? (Any other render goes ok(Scanline, Vray, Mentalray, etc).
yes, loocas had similar problems. Add me on skype if you have time, we can debug it.
Sure. I am on a hurry by now, but i will add you Keymaster.
BTW, sorry to not mention, i am using the A5 (stable). Not a daily build.
I reported this issue a while ago and it seems to be fixed in the daylies - tested it here with a couple of REs and everything works as expected. The problem were some standard properties in REs which were not existing in corona and crashed the script.
ah, crap, then there is another problem
