Corona and Forest Pack Pro crash
Im having a problem with Forest Pack pro in Corona. Material are converted yet when I go to render the system crashes. Im using Forest Pack Pro 3, could this be the issue?
Has nobody had this problem before?
What version of Corona are you using? Can you post a simple scene that crashes?
Hi Keymaster,
I still havent resolved this, Ive attached a simple scene. Im using the A5 Corona build.
corona_forest_crash_scene01.max (80 KB)
It works fine now, the problem was probably already fixed
Ah, I re-installed Corona_A5 and still have this problem.
it will be fixed in the next stable release, alpha 5 is old one
Great. Do you know when will that be? It may be I need to switch engine for a live project.
hopefully soon :wink:
