Corona and liquid: OneSide vs TwoSide vs Hybrid
unfortunately, with Corona is impossible to render, correctly, liquid inside containers. Look at the images.
Also, with VRay I can achieve better (correctly) result in less time (VRay-RT GPU Nvidia 560GTX)
In Corona, water is dark.
() In my render I used a solid box for the water (PT+HD)
) The refraction color is perfect white
Old problem. For this you should use Bidir/VCM with solid refraction mode or set MSI to some high value or 0 and wait wait wait until it refines.
until you use specular light sources, you can get away with this by increasing MSI :wink:
I know, it’s old problem. Jut I found weird the shadow inside the container when I use Hybrid.
() I tried with 800 and 8000 MSI + progressive mode. I have dark shadows inside the container. It isn’t like VRay.
) Bidir/VCM is just experimental right now.
So I guess hybrid mode doesn’t cast direct shadows but blocks GI.
duplicate of a mantis entry
