Corona and Phoenix FD 2.2 compilation test///
Corona 1.5 daily Build from 8 2016, Phoenix FD+ vray 3.3 for sea simulation,Marvelous Designer for sail and flag’s animation//
Post’s are welcome:)
Simulation of water with Phoenix FD/ Ship and background with Corona/and water and foam with Vray/after this compositing in After Effect///
It happaned much,much faster in render///
brute force from VRAY is still very slow for rendering object topology changing in animations///
With Corona this much faster and correct///
But I would be very happy to render all scene in Corona render, but in the absence of at least open VDB format support in Corona it’s impossible:(
I know about this///
But Corona still not supported Phoenix as it is:(
Phoenix can be used with Corona only with different trick’s /etc. exporting geometry to Corona Proxy and particles to PRT. BIN. ABC, openVDB formats or using outsiders plugins, Krakatoa atmospheric effect and
compositing —for example ///
thank’s///
he/he:)
I think it does not matter so much///
The flag and ship exactly rendered with Corona:)
And using environment from other’s render engines the same, as using backplates and HDR images from other’s image resources:)
And last top short is fully rendered with Corona, where exist only some compositing effect with foam and clouds from Krakatoa Render engine///
i am new in corona and still try to do same stuff than you !
May i ask you how did you do manage to render properly the vector displacement of the FD ocean displacement map, I have some problem of direction wave, like if we have to invert RGB color or trick something to get something correct ? do you work with unit scale meter/meter ?
you manage to get very sharpy wave with large swell, i guess you manage to blend different displacement map between
I am very interresed by your R and D. if you can help me that would be great !!
