Corona and start animation export with vantage issue
I’m encountering a very bothering and frustrating issue with the animation export from the render menu/ system / from corona.
The start animation export button in the render settings menu from corona, when clicked does not launch the sequence but instead opens chaos vantage in the global scene window.
Don’t have access to the sequence render menu on the upper right corner. Because after clicking the teapot to render the sequence is greyed out. So impossible to launch the animated frame sequence in vantage to calculate. It should directly show the common settings menu with the sequence module active not the still image.
I have to close, launch, close and launch chaos vantage again. Click a lot of times on the export animation to vantage button from 3dsmax corona render settings menu…and then try launch the vantage live link…stop it again and close vantage again. launch the button export animation to vantage once again and then with a good portion of luck…tadaaa finally vantage opens with the correct render menu and sequence module no longer greyes out but active with the render settings on the right where I can adjust output and render settings, frames etc. So this behaviour is really random and should be fixed ! As it is horribly frustrating to work like this. As intended it should with a single click on the vantage animation export launch vantage, which opens with the sequence menu displayed and active.
Also for precision I’m working with corona 13 hotfix 2 and vantage 3.0.2
thank you for your feedbakc and future hotfix on this.
kind regards,
Matt.
We already have this logged as (Report ID=CMAX-1935) and hopefully it will be fixed in Corona 14.
As a possible workaround, you can try downloading and installing Vantage 2.8.1 - Download | My Chaos
Hi!
I confirm the same behaviour unfortunately!
I need to finish an animation and I’ve found out this issue right now.
Any plans on when this bug will be fixed? :folded_hands:
Thanks,
Dionysios -
Please try using the newest Vantage 3.0.3, it should work correctly there - Download | My Chaos
Hello Maru, yes I confirm the 3.03 resolved the issue!!!
Thanks :smiley:
Dionysios -
Great, thanks for confirming!
