Corona Attributes Window
Hi!
In C4D R25, the Corona Objects, like the lights have incorrect formatting in the attributes window.
I enclose an example of a Corona Light and a C4D Light.
Can you solve this problem?
Thank you very much!
Hi there, thanks for bringing this to our attention. We will look into it further.
Hi there,
Could you please tell us a bit more about your computer?
(CPU model, OS version, installed RAM, installed Graphics card)
Regards.
AMD ryzen threadripper 2950x (16 core)
32 gb RAM
nVidia Quadro P2000
Windows 10
Cinema 4D R25.010
Corona 8 (DailyBuild Sep 15 2021)
this happens because some portions of our Object UI do not fit the width of the screen (in this case, this is a conjunction of “Shadowcatcher Illuminator” being quite too long, pushing Units with a dropdown menu to the side). The underlying cause is, however, that Maxon reduced the width of this portion of the screen in R25. You can simply increase the width and save that as the default layout.
We will see if we decide to change the layout of this.
Thanks,
Jan
