Hi guys,
Just wanted to know how you are using back burner with the progressive mode.
Do you rather set a fix amount of passes or a time limit when you send it to your farm?
I came across the issue that if you do not set any of the above and you decide to manually go on your nodes to stop the rendering process, you would not be able to save your image? (Unless you set a path before to sent your job to the farm maybe?)
Is there any possible way to play around with the Iso and shutter speed on a node or do you have test render it on your workstation before to send it to the farm?
Also, the Corona VFB doesn’t automatically update on my nodes, I have to play around with the Color Map values to refresh the image, if that make sens…? Normal?
Yes, some random questions…
Alex
EDIT: Is there any possible way to play around with the Iso and shutter speed on a node or do you have test render it on your workstation before to send it to the farm? CoronaCameraMod is probably a good start
