corona batch processing
quick question, I have had a bunch of files rendered as cxr’s by rebus, have used the batch processing ultity before, upgraded today to corona 3, run the batch file and it doesnt recognise the .exe
see attachment
sorry legible attachement this time
ok.. tried unistalling cornoa 3 (had some issues) installed corona 2 and the batch processing worked. so corona 3 batch processing working?
The executable moved to a subdirectory “Image Editor” since v3. You have to adjust that line in the batch file (add subdirectory):
set editorExecutable=C:\Program Files\Corona\Image Editor\CoronaImageCmd.exe
Good Luck
perfect, many thanks..
do you you how to save 16bit PNG’s at all???
I just tested to set “outputFormat=tif”. A tif is written, but a mess of a LSD-tif :smiley: Additionally I don’t know how to set bit depth and alpha options by batch, looks like there are currently no parameters for it. Smells once again like a bug/feature request.
Good Luck
The feature request is already logged.
(note to self id=298353314)
