Hi.
We usually use this batch render script for Vray and it’s great
However, this doesn’t work well with Corona.
It doesn’t work well with lightmix’s or denoising.
Is there a script like this for Corona?
Hi.
I’ve been using Pulze scene manager for a while and it is quite cool. It also lets you set up all different light and layers scenarios for each camera.
It’s a paid solution though. Scene Manager - The Staging Tool for 3ds Max
I use the batch render script that you originally mention, and haven’t had any issues using with Corona (including Lightmix, Denoising etc) - if you render our to CXR you can tweak everything later in Corona Image Editor (in Max or independently).
I recently used it for a project with 16 panoramics and it worked a treat!
yeah… try doing that way with a animation @ 30 frames / second. Your time to process all those frames is equal to the rendering itself. Not recommended
I do believe there is a batch CXR editor plugin available…might be of some use to you?
I used this once when its beta was released, it crashed about 30 seconds into use. I gave it another shot when it was fully released and it immediately crashed again. Gave up after that…
i was already referring to the batch editor
I’m not sure the original post has any mention of being used for animation - completely agree that this method wouldn’t suit animation. The original post mentions issues with Lightmix and Denoising, both of which I’ve found to be fine using the batch render plugin?
