From the start check temperature of cpu while running test.
Check cpu usage and make sure what 100% load for corona test or other process?
Make sure what you install all drivers in device Manager
Looks all fine.
Check CPU frequency during test maybe it has wrong values.
Did you try to reset BIOS?
Also you may try other benchmarks like cinebench and games.
Does it happen with any other apps that put the CPU under load? Lots of things out there that will do that to test stability. Just thinking aloud, any issues with the PSU?
The guy basically had my same problem, so I performed a BIOS flashback via USB to version 0905 and the magic happened: Corona benchmark now runs in about 1min at more than 8millions ray/s, just as it should be. LOL.
Thanks to all of you for your support and your suggestions, I just hope that my experience could help someone else in the future.
Classic bios shanenigans of niche boards (Asus WS series) on niche platforms (x299/x399), always suck : /. The manufacturers just don’t care.
Sometimes it’s good to check overclockers.co.uk or how is the URL, there are user groups where people offer custom bios so they can fix your issues faster.
