Ever since Adam and Eve were knocking about the 3dsmax Bitmap had no way to lock the aspect ratio of a map. A Lock symbol for U or V and the field greyed out depending would be a tidy solution I suppose. In real world and tiling mode, be awesome.
Also, view bitmap in the map itself where you can affect the bitmaps crop/place. At the moment it, seems a bit clunky IMO.
Where it says ‘load map’ perhaps this can be the bitmap name. And any additional info in the lower section.
And maybe a button where you can save favourite locations or maybe that’s asking a bit to much. ;]
Thanks guys.
EDIT:
Tabbing / shift + tabbing back and fourth between U and V fields would be a plus ![]()
BUG/MISSING: Right click on map in slate material editor to edit.
