Corona Bitmap Issuu with 32bit EXR
I’m working with a mapped network drive (P:) that points to a folder on my main disk (N:).
All textures load fine except EXR files when using Corona Bitmap. In 3ds Max, those materials show up black, and I get this error:
“Could not load texture file… Could not open file…”
The path is correct and accessible. If I replace the EXR with JPG or PNG, it works. Also, if I load the same EXR from the original disk (N:), it works perfectly.
So the issue only happens when using the mapped drive (P:) with Corona Bitmap. VRayBitmap and the default bitmap load the EXRs without problems.
Any idea what could be causing this?
Hi, I have just started a support ticket #478724 for you since I asked for some information which you may not be comfortable sharing publicly. You should get an email notification.
