I have BG image, 9005 × 2942 px
Corona bitmap shader renders it burry, c4d bitmap shader render sharp, any ideas on what is going on?
Hi Daniel, Can you tell us more about the setup? How are you using the image? Is it applied to a background object, a plane, or a Corona Sky for example? If you’re able to send us a stripped back version of this, that would be great. Chaos
Hello, It is plane with opacity applied to it. I have uploaded scene with only this plane.
Daniel
Hello Daniel,
thank you for sending the scene over, it really helped us!
For now, we don’t know what’s causing this issue, however, there is a workaround. By setting the Blur Scale value lower you can get pretty close to the native bitmap look. Or you can simply use the native bitmap ![]()
We’ll look further into this.
Thanks,
Jan
