Corona bitmap scale changes on merge
Merging a geometry with a corona bitmap diffuse map with world scale (I suppose it’s the same with other maps) from a scene with a different system unit (ex. from inch to cm) Corona scale map size. It works fine with Max standard bitmaps.
In the picture you can see the imported box, the right one with max bitmap, the other with corona bitmap, the last one size has been divided per 2,54
